It is currently Tue Aug 05, 2025 8:14 am
 Post subject: Raduis Dish Opinions?
PostPosted: Sun Mar 22, 2009 10:11 am
Currently building #'s 3 and 4 with my dad.
1 and 2 were built without a raduis dish, and #1 is a canon, #2 is mellower (but #1 was a Dred, and #2 was an 0-18).
We are going to build a gobar deck for the next ones to simplify the bracing.
Is there anything inherently wrong with building without a radius dish?
These are going to be twin Dreds with bubinga backs and sides.
Thanks. ad
PostPosted: Sun Mar 22, 2009 10:26 am
I think we need some more information to answer your question. Were the first 2 guitars built with flat tops and/or backs? If not what method did you use to get a radius onto the braces and glue them to the top? And if you did use radiused braces did you translate any radius to the linings before you glued the top and back on?
There are many systems used to give a radius to the top and back and you do not need a dish to do it but the dish is an excellent tool towards repeatability and clean tight joints.
Burton
Brookline, MA.
PostPosted: Sun Mar 22, 2009 10:33 am
Last Name: Vitale
As a new builder, I let radius dishes keep me from building for a long time (Too cheap to buy one; too lazy to make one). I assumed I needed the dish to build correctly, so things did not progress very well. Finally constructed radius boards out of 3x3x24 wood. Used these to clean up brace bottoms after planing the braces to radius and also to "freehand" sand the radius onto the side edges and blocks. I was nervous about it but it worked great. I use cam clamps instead of a go bar deck, and this works well for me too.
PostPosted: Sun Mar 22, 2009 11:20 am
the tops and backs were built flat, no radius on the bracing.
PostPosted: Sun Mar 22, 2009 11:38 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I doubt you'll see any or much difference in tone, but I fear the guitars will be very sensitive to humidity changes. ALOT of builders use flat tops but I don't know of anyone who uses flat backs.
FWIW, I'm no expert. I DO KNOW WITHOUT A DOUBT that there's more than one way to build a great guitar.
PostPosted: Sun Mar 22, 2009 1:34 pm
Last Name: Hodge
I have a fully equipped woodworking shop so making a radius dish is no problem in my shop.
However, if you're not equipped to do so, or you prefer an alternative method to a radius dish,
Kenneth Michael has posted a page on his site that offers a simple method with 3x5 card stock.
Here's the link: http://www.kennethmichaelguitars.com/contourtool.html
Bill Hodge
PostPosted: Sun Mar 22, 2009 5:54 pm
I bought two dishes w/sandpaper from Tracy at Luthier Suppliers, backed them with 3/4 ply, then sealed by spraying a coat of shellac. They've made bracing, profiling the rim, and gluing the top and back to the rims so much easier. So much easier. I know they're pricy, but along with my handplanes, they're easily my best investment so far.
PostPosted: Sun Mar 22, 2009 9:09 pm
I made mine and it wasn't too bad and I'm glad I've got them. But, if I need more I'll probably just buy them as long as I can afford it.
PostPosted: Mon Mar 23, 2009 12:42 pm
First name: Randolph
Last Name: Morris
I built my radius dishes with a table saw and a router. I have to say it for as stressed as I was about the whole thing before I started, it was one of the most fun projects to date. It sounds like you and your dad are going to keep building, so why not think about a radius dish project? idunno
